Delayed Ignition Statup
Braindead
5
Burnaby BC Canada
Rangers
8"electric, 2.3, 4.0-OHV, 4.0-OHV
They say it can't be done, so I did it. Again
I have had many vehicles that have bad rattles when cold starting and I sometimes would turn the key and shut down before the engine fires. I would attempt this couple times before letting it start running. I found this to be inconsistent because sometimes it would start before I could catch it and then the rattling may or may not occur or just not be as bad.
Recently I started testing a bunch of electronic timers for consistency of operation. The timers I have are from elevator systems and seem to be very accurate even though the battery is below the rated voltage requirements of the timers (24 -240volts AC/DC). The timers have settings from 1 second up to 1024 seconds in one second intervals. As I am unsure as to their durability under load or what the duty cycle is I was thinking about using a solenoid similar to a Ford starter solenoid except designed for constant use to trigger the ignition after the timer fires so the engine will spin for two, three, or even four seconds before the ignition receives power to pre lube the top end.
Has anyone here tried anything similar?
Will this have any negative effects on the computer?
Where would I interrupt the power on my coil pack engines?
I am planning to use the timers on several vehicles if it works.
I am expecting the timers will allow the engines to last much longer than without them.
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
Starting RPM should be around 300, idle probably 600-800. I'm not sure you'd really accomplishing that much. Plus the oil pump is moving more oil at the higher RPM. I think the better option would be to run a quality oil and keep it changed at the proper intervals. If the engine is rattling at startup, there's more than likely an underlying to be fixed.
If I were going to do something like this, I'd be more inclined to install a momentary switch to kill the ignition while cranking. That way I wouldn't have long cranks every time I turned the key. So if the engine has only been shut down for a short period, it would crank right up.
Just my thoughts. I see your point, I'm just not sure it would really do all that much for longevity.
Something like this could be used to pre-charge the oil pressure prior to cranking.
https://www.summitracing.com/parts/mor-23900?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-moroso&gclid=CjwKCAjw5pPnBRBJEiwAULZKvqZ2ceVw5fHKUGOSW-eJdFJfhEKghTjlzBqNTCDy4slEyM6Zc795rhoCAnsQAvD_BwE
As long as you close the valve before shutting down the engine, the system would hold pressure. You'd open the valve right before cranking and leave it open while running it would build to the same oil pressure that the engine is running at. You can even use solenoids to open and close the valve with the ignition.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
To delay start up on any fuel injected engine... hold the throttle pedal to the floor. That will shut down the fuel injection... it's called clear flood mode.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Ummm if your goal is to just prime the engine before starting wouldnt it be a hell of alot easier to just add a kill switch to the fuel pump relay instead of adding elevator timers? :icon_confused:
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
There is no clear flood mode on pre obd2 rangers.
17,827
SW Iowa
That does work on carbed trucks. Gets a lot more air into the system to help with a flooded engine.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Hmmm.... I thought that every EFI system had clear flood mode.
