Duraspark/HEI swap help
lilbdfrd
Wilcox,NE
Ford Bronco ii
Yes, thats usually the case
Ok thanks !!! So the purple that went to the yellow wire originally goes to yellow on coil for power “on” right?
lilbdfrd
Wilcox,NE
Ford Bronco ii
Yes, that can be the case
But its usually Red + and Green -
Not familiar with yellow being used as +, but never had a 1984 Ranger
And just FYI coil "-" is not a ground per say it is the control signal that sparks the coil
Coil gets 12volts with key on, on "+" terminal
The distributor/module connect and disconnect the "-" terminal to spark the coil, it sparks every time it is disconnected
"-" is used because when there were points inside a distributor it was just easier to use "-" than "+" because of possible shorts
The points connected and disconnected "-" on the coil
This type of Electronic ignition just replaces the points opening and closing with transistor opening and closing to cycle "-" terminal on the coil, so no moving parts to wear out, although these can wear out, :)
Here is a picture of the plug in on the side of my coil!
8,290
Dark green was common color for "-" on TFI systems
But only seen red on "+", as said
You could just unplug them and use a test light or volt meter
lilbdfrd
Wilcox,NE
Ford Bronco ii
I used a muilti meter and checked every wire coming out of the main 6 wire harness and I had NO voltage anywhere while the key was in the on position! I even to a wire straight from the + battery terminal over to the “hot” side of the coil and still had no spark?. Any other ideas ? The engine cranks great!
Kirby N.
March Truck of The Month
