electirc windows
motocross
CANADA
hi i have a 1988 ford ranger with electric windows and the passenger one dosnt roll down or it does about a inch then stops and wont go up, it sounds like a stripped gear no prob but i was looking for one and this is all i could find , will it work
http://cgi.ebay.com/ebaymotors/FORD-RANGER-POWER-WINDOW-MOTOR-GEAR-KIT-SM-OEM-85-86_W0QQcmdZViewItemQQcategoryZ33706QQihZ007QQitemZ170143240004
also i was looking around and it might be the bushings in the motor but they also say 85-86 is there a diffrence because it seams the same to me. thanks
envious8420
8
murphysboro il
2.3
yeah that one should work.
but you have to pull the window motor to change it out so it might be more cost effective to switch out the whole motor.
jim
motocross
CANADA
so what do you think should work the window gear or the bushings ?
envious8420
8
murphysboro il
2.3
well the gear should work for your application.
without seeing it i cant tell you what it needs.
if the bushings are bad the motor will have issues and will make noise like a stripped gear
comm/stator against the motor can/magnets
if its the gear, same noise.
best to take it out for verification.
motocross
CANADA
ok ill try to 2night some time
motocross
CANADA
well tonight i took it appart and everything looks fine but the motor wables when you push up or down but its in there tight so i might just try find a whole new motor
Mutant Pony
9
Hersey, Mi
2300
It is the same motor that ford used since the late 60's. They didn't change them 'till sometime in the 90's. The window regulator is strictly Ranger of course. There are left and right motors that do not intechange and sometimes they used them in the opposite sides.
With the regulator intalled there are three little divots in the bottom of the door that coincide with the screws in the motor. If you drill them out to 1/2" you can replace the motor without removing the regulator. There may be a hole or slot instead of one of the divots.
motocross
CANADA
ok thanks alot i couldnt figure out how i would get it out
