MAKG
- Aug 7, 2007
- 19
- California central coast
- Ford
- Engine Size
- 4.0L
NO!
Try a REAL bicycle generator.
It takes MORE effort to turn the pedals at a given RPM (and given gear) with more load. As was said earlier, it's not just rotating mass. You're making and moving around strong magnetic fields. These are not free. They take a LOT more energy than simple rotating mass.
For the alternator, it's a regulated system. The field coils are turned up or down to produce the same voltage regardless of RPM. When they are up, it takes more effort to turn. There is nothing magic about this; it's just a feedback circuit where the field coil current is controlled according to whether the voltage is higher or lower than the setting.
Energy is neither created nor destroyed. If you draw energy from the battery, you must replenish it at the same rate or it discharges until it dies. This energy MUST come from the engine; there is no other source. You claimed otherwise. That's perpetual motion.
