TFI module images here:
https://www.stangnet.com/mustang-forums/attachments/tfi_5-0_comparison-gif.250293/
There are two versions, grey and black, wiring is different so not interchangeable
You should have a Grey one on a 2.9l Ranger
Called "Push Start" version but nothing to do with bump or push starting vehicle, lol, it has a separate power path for START and RUN voltage.
And you should check those, RUN Power with key ON(12 volts), START Power with key turned to START(10volts), BOTH need to work
Coil NEGATIVE wire should pulse when distributor is turning
Unplug the coil's wiring connector hook volt meter or test light to Battery Positive
Hook other lead to Coil Negative wire
Crank engine, watch for pulses
If it pulses then TFI is OK
Now switch Positive wire to Coil "+" wire on connector, repeat test, if no pulse then coil is not getting 12v with key in START position, actually gets 10v
