Engine swap questions
meck
Madison County, KY
1994 extended c
I'm still trying to figure out ahead of time what problems I'm going to have swapping a '97 3.0 engine/tran into my '94 2.3L Ranger. I'm not doing this for speed or such, just to replace a very tired engine. I'm wondering what problems I'll run into putting an OBD-II engine/tran into an OBD-I Ranger. If anyone knows of a thread about this or can give me some advice, I'll appreciate it. (I have the entire '97 donor truck).
Evguy1
Errington BC
I think you will be shocked at the fuel consumption of the 3L.
Go for a TDI diesel swap and have good power and much better fuel mileage.
There are a number of build treads on this forum about the TDI swap.
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
A TDI swap would really be a hassle.
The 3.0 should average 20ish, if youre not Bo Duke.
Youll need a trans and motor mounts for sure, possibly a radiator. (Not sure if the 2.3 ran a different one).
As for the wireing, i would think you should be able to just pull the entire harness and swap over, but the cluster might be an issue. Since 94 was the last year of the circa 89 dash.
meck
Madison County, KY
1994 extended c
Thanks for the positive reply. After going over the wiring diagrams for the two years, I'm thinking the swap is very doable. I haven't checked yet to see if the split vss/speedo drive on the '94 will fit the vss only drive on the '97 trans. If it will, then the '94's speedo will work. If not, I'll swap in just the '97 speedo as the rest of the gauges seem to work the same.
Anyway, I'm going to give it a shot. And the gas mileage of 20+ sounds fine to me.
Thanks again.
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
Youll need to use the 97s transmission. A 2.3 trans wont bolt behind a 3.0
EDIT
I read that wrong. Yeah, i have no idea about the VSS. Did the 97 have the key anti theft? (PATS)? That may also be an issue.
meck
Madison County, KY
1994 extended c
No PATS on the '97. Nothing else fancy, either. And, yes, I have the '97 engine and transmission. The donor truck has a new radiator, so it will definitely be swapped. The steering columns are different, so I'm getting a '94 one for an automatic from a junkyard. Will rebuild it, if needed, before installing.
8,370
yes, the swap is possible with donor vehicle
You will need to remove the 2.3l engine and trans
Remove the cross brace for the 2.3l's engine mount
3.0l engine mount holes should be pre-drilled but can't say for sure
Trans mount should be the same
The 2 Fuel lines should be long enough but may have different ends, one is IN from Pump, the other is OUT to gas tank, don't mix up the 2, lol.
ODBII in 1997 is just for engine operation and trans if automatic
You will need the 3.0l exhaust system swapped over and it will have the 3rd O2 sensor used with OBDII
As said engine and trans needs to be swapped and drive shaft most likely
Most engine bay parts like air cleaning MAF setup
EVAP system may need to be changed
1997 still used VSS on trans or transfer case so not an issue, you can swap over the 1994 speedo cable/VSS unit to use in the 3.0l trans, it will also match current rear axle ratio.
In 1997 the VSS signal ran to GEM, Computer, speedometer and Cruise(if so equipped)
You won't need the GEM since 1997 used transmission VSS but you do need to make sure VSS is connected to pin 58 on Computer, it should be already, but just double check
The dash gauges are all the same, analog, fuel, oil, and temp
If you have a tach that may need to be changed to read correctly.
Denisefwd93
74
South East PA
It took me 3 years, and like you've been studying for years finally in the end I just got another truck.
8,370
Yes, I agree
2.3l to 3.0l swap is not an upgrade and not simple
Selling the 3.0l to some one that needs a 3.0l and then rebuilding the 2.3l would be by far a better investment in time and money, but OP must have his reasons to want to do it.
But its not because it makes sense, because there is no "upside"
meck
Madison County, KY
1994 extended c
Some good tips in there RodD. Thanks.
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
Yes, I agree
Why isnt it an upgrade? The 3.0 makes considerably more power then a 2.3, hes already got the parts, and the 2.3 is shot anyways. Why spend money rebuilding a 4 popper thwt makes 88 or so HP when with a little homework you can have an engine thats just as reliable, and makes ~50hp or so more and 65 or so more FtLbs.
Plus, its not like hes trying to swap in a 3.3L from a caravan or something, the truck is engineered to accept that engine.
8,370
Used or rebuilt 2.3l will get better MPG than 3.0l, which was the point of the 4cyl engines, and it is plug and play, same engine.
3.0l Vulcan had the nick name of 3.slow, enough said :)
Installing a different size engine is basically the same work regardless of the engine size.
And because VIN no longer matches engine size it may get tagged with a Salvaged title when registering it, depends on state.
If more power was the goal, not MPG, then 5.0l V8 from Explorer would be the choice, not 3.0l or even 4.0l.
Ranger can fit the 5.0l explorer V8 because they are basically the same engine bay, yes it is tight but exactly the same work is required to install the 5.0l as the 3.0l or 4.0l when it comes down to it.
And a V8 is an upgrade, for 2.3l Ranger, or 3.0l or 4.0l Ranger for that matter, lol.
If you already have a donor 3.0l then sell it to someone that needs a 3.0l engine and/or trans and other parts from a 3.0l Ranger
Then find a 5.0l Explorer with bad body
Or sell the 2.3l Ranger and buy a 3.0l Ranger with good body and bad engine and/or trans and use the current donor for that.
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
I mean, obviously yes, a 302 is better, and besides a 2.8 the 3.0 is the weakest 6 they used in the ranger...
But, it still beats the hell out of a lima.
17,822
SW Iowa
FWIW I have never heard anyone on here have to go thru that. Can be some hoops to jump thru for emissions if they care about that in your area.
You can get a lot of time/effort/parts in a stupid power train swap. I wouldn't do it for anything smaller than a 4.0... and it would take a lot of soul searching to do that over a 5.0.
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
I feel like hell has frozen as i sit here typing in defense of a 3.0...but...
Yes, a 4.0 would make more sense, but not as much as a 302, but then again a 351 also works, but hell, since im changing shit anyways might as well go for a 460....
Not everyone rides that train of thought.
He already has the 3.0 donor, and at the end of the day its his truck, money, time and choice. Hes obviously not really dojng this for MPG, prolly not really for power either, he just wants to get his truck back on the road, and i respect that. I take all kinds of shit for my automotive descion making (like when i passed up powerchokes for a good ol 460 for towing my camper), but, the difference in opinion is what makes the world spin.
Personally, ida went with a 2.9
