Doom's Day Custom
- Sep 23, 2009
- 5
- nj
- ford
- Engine Size
- 4.0l
Original Poster: JAY AKA (Doom's Day Custom)
Difficulty: 3 out of 10
Time : 30min but have to wait till glue dries
Disclaimer: The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums.
Brief Explanation:
I have done this because my truck kept throwing up codes ,saying the evap canister is bad and need to get replaced... I don't see paying $50.00 buck for a plastic box full of charcoal and this rebuild cost me barely $20.00 which is a good saving of $30.00 buck plus tax
Tools Needed / parts needed:
-socket wrech w/ sockets
-glue for plastic (i use arrow glue and all purpose glue from home depot)
-hack saw
-small screwdriver
-pliers
-fish tank charcoal
-vise or something to hold the cansiter
-brake clean
Steps:
1.Take all the hose off the Evap cansiter and unbolt it from the bracket and remove it from the truck..
2. Put the cansiter in a vise upside down and tighing it( Don't tighting the vise to much that you crush and distroy it)
3.Take the hack saw and cut right below the lip on the bottom and stay as close as possible and keep cutting till the bottom is off..
4.Set the the bottom to the side and now take the screw driver and pliers and pry the clip off the rod and pull the screen off and set it to the side .. Take the cansiter and dump the out the old charcoal..
5. Reach inside and pull the 2 green foam filter out and clean them with brake clean and the reinstall them..
6.Pour the new charcoal in the cansiter till about the same level as it was before..
7.Reinstall screen and then the clip
8.Glue the bottom back on the canister and i held it togther with duck tape
9.When dry reinstall in bracket and connect hose in the right manner
Your Done
Thanks
Jay AKA (Doom's Day Custom)
Brief Explanation:
-hack saw
-small screwdriver
-pliers
-fish tank charcoal
-brake clean
Steps:
Your Done
Thanks
