Ford 2.8l rebuild question
Kanakin
Fresno, CA
Hi, I'm rebuilding my daughters 2.8l and there's a bolt hole next to one of the main bearing caps and I don't remember what goes there. Any help will be appreciated
http://imgur.com/ZzDTXjM
1990RangerinSK
1,312
Saskatchewan, Canada
I've never seen the inside of a 2.8l engine, so this is just a shot in the dark. A bolt goes there. :)
I'm sorry, I'm a bit of a smartypants, and I couldn't resist giving you an answer that was incredibly obvious :D
saskbill
6
Saskatoon, SK CANADA
Don't know - have had a couple of 2.9s apart (kind of sisters) and this doesn't ring any bells for something mounted there. Hopefully someone more experienced will chime in.
Just a thought - some of these engines have threaded plugs to close up oil galleries, which of course get removed when the block fro example gets hot-tanked to degrease and de-crud. Not saying this is one, just a maybe...
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Looks to me like a mounting hole for the oil pump pickup tube for a different style oil pan. The 2.8 was used in ALOT of different vehicles so it came with many different oil pans and pickup tubes and obviously they would need different mounting locations. If it was a oil galley plug it would be NPT thread.
kimcrwbr1
46
maplevalley WA
2.8l
Maybe for a baffel plate to keep oil from splashing forward when you hit the brakes?
AndyB.
142
Cincinnati, OH
I just went through the pictures from my 2.8 rebuild. Nothing is bolted to that, potentially a galley plug goes in there, but I’m not positive.
enginepaul
12
Northern California
2.8
You're probably done by now, but I don't recall that bolt hole holding anything. I haven't done a 2.8 in over 15 years so I may be wrong.
