BryWink
- Sep 24, 2017
- 0
- Ford
Hello, i know that their are plenty of posts on this. but most of them ramble off topic. I found a good deal on a 1993 taurus SHO motor with everything to make it run. It came out of one with a bad transmission 71,000 miles. stored in a heated garage. What all do i need to know about this swap. pilot bushing the same on my m5od 5 speed trans? clutch? flywheel? clutch splines? i know the intake needs to be swapped around to be on the correct side. what about the a/c pump? power steering pump? alternator? will any of these be plug and play or do i need to use everything off my stock 3.0L motor? can i run my stock fuel pump? lastly i know the SHO motor has a much higher redline, what will i need to do to have the stock tach match correctly with the new motor?
