Freshmeat
- Aug 2, 2009
- 40
- Denham Springs, LA
- Ford
- Engine Size
- 3.0
- 2WD / 4WD
- 2WD
Okay- the D35 is torn apart. I had the spider gears welded and I pulled the C-clip. Going to finish cleaning up the center section, replace the seals, then re-install it, then start replacing the U-joints (with full circle clips and 5-760X joints) on the shafts, open up the passenger beam window a bit, and grind on the inner most yoke for the passenger shaft so it can angle downward a bit more without binding.
Time for a parts store run for seals.
