Friction Modifier In P/S
15
kansas
I was wondering if anyone has ever tried putting friction modifier in any ford power steering, it makes sense to me but I want to know if someone tried this and it works
8,370
There are different types of friction modifiers
For limited slip differentials , posi-traction, they decrease friction which allows the clutches to slip when going around a corner
For an automatic trans they increase friction to limit slipping
At one time Ford did recommend adding the differential type friction modifier to its power steering pumps to reduce noise
15
kansas
thats what im going for, i work at a parts store, I dont have access to motorcraft, so I'm not entirely sure what product I should use, this thing is annoying and its hard to believe no ones solved this issue before
fastpakr
2,832
Roanoke, VA
What issue are you having?
8,370
Try the K&W trans-X posi-trac additive, your store should carry that
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
@RonD how did you know what his store carries??? Did I miss where he said WHICH parts house?
15
kansas
Yes...more importantly RonD, when were you going to tell me you're a wizard
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
it only takes a few posts from RonD to know that his wizardry is unparalleled.
Josh B
1,986
Oklahoma
How much would you use in a PS pump, and would it be useful on my 93?
Fact is I have some leftover from a recent rear end rebuild just sitting on the shelf
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
If I've said it once, I've said it a thousand times... use placenta for power steering fluid.
On a less serious note, I'm sure Ron knows but wouldn't a friction modifier made for transmission use be better than that used for differential use since the power steering system is using ATF and not gear oil?
8,370
No, you want less friction in power steering pump not more
Ford power steering pumps are just noisy, Ford deals with that by installing A VOLUME KNOB on every radio they install in every vehicle, never seen a Ford radio without a volume control, now you know WHY :)
On newer models they even moved it to THE STEERING WHEEL, point made, lol
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Last time I flushed my power steering system I filled it up with mercon v that I had previously mixed with lubeguard red when I flushed my transmission. Not because I thought it would help or hurt, I was just too cheap to buy more mercon. I dont think lubeguard red is actually a friction modifier but my pump seemed quieter than with previous flushes. :dunno:
But yea... they make noise. I'd be more worried when a ford PS pump STOPPED making noise. Because it probably fell off.
