front coils
Denisefwd93
74
South East PA
I haven't found it but I'm looking for what the stock height would be with the original front springs on my 94 four wheel drive 4.0. I'm aware of the washers to give a slight lift in the front but it seems to me it's the same amount of work as replacing the front springs although the cost way more.
I'll go back and re-read the help pages again but i didn't quite find the answer to my question about ride height in the front,
Uncle Gump
Token Old Guy
13,437
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I have a brand new pair of MOOG coils I bought for my 94 4.0L 4WD. Also a set of energy suspension spring isolaters. The old Camper Special just doesn't fit my future plans and I won't be needing them. When I get home I will put up part numbers... and if they are indeed what you need... we can figure out a good deal for you.... if you're interested.
Uncle Gump
Token Old Guy
13,437
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Moog CC870... Let me know if interested.
If not they will end up in the garage sale and/or posted up here.
Denisefwd93
74
South East PA
UncaG! I kind of decided on polyurethane blocks after reading that they've lasted over 200,000 miles on the four-wheeler forum. what do you want for these springs with the isolators? I've never seen prices vary so much as they do on springs! RockAuto is around 50 60 bucks for them. Then there shipping cost to 19007, just about every time I go to buy something online I go back to Amazon and free shipping come out ahead of every time I love RockAuto but shipping cost usually cancels out any discounts & lower prices but not always
Uncle Gump
Token Old Guy
13,437
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
If you have the original springs under your 94... blocks are kinda like a band-aid. In my opinion... you could benefit more putting a new set of coils on it.
When I bought the coils... I also bought 4 Rough Country shocks for a 1 to 2 inch lift and a Rough Country steering stabilizer. I installed the rear shocks and the steering stabilizer but the front shocks are new. When I went to install the front coils... I took a closer look at the overall health of my 94. I decided to just upgrade the truck. I planned on removing the rear shocks and stabilizer this weekend because the truck has to go soon. If you think you could use all of it... we can discuss that possibility too.
If interested in any or all of it... send me a message and we can get you what you want out of the lot on the cheap.
Denisefwd93
74
South East PA
Bummer! Put new shocks on a truck last summer!
I'm going to get under the front and find out where the optimum "height"is compared to where it is now, Moog CC870 seem to be stock height coils, I'm going to look again, but it appears that someone did something to the front spring height, and as I mentioned in another thread the rear shackles were upside-down
Thank you UncaG! .. much to consider!
Uncle Gump
Token Old Guy
13,437
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
All good... the coils aren't going anywhere soon. You have some time to figure out what you want to do.
They are stock height coils... I was going to add a block
Denisefwd93
74
South East PA
I may not even need front coils at this point my truck is totally different since I had the back shackles flipped down to where they're supposed to be, it feels like a totally different truck! The back is high like all the rangers when they're empty in the back, the front seems to only be about an inch or two lower, truck certainly looks better and actually looks like the four-wheel drive it is!
