mtnstyne
- Nov 9, 2019
- 0
- 38506
- Ford Ranger XLT
2002 XLT 4x4 passenger side half shaft replacement. When I went to separate the half shaft from the main axle it didn't separate correctly. Instead the main axle is still tightly connected but pulled out with the half shaft from the differential. I can't pull it completely out due to the length and other parts in the way. Is it safe to brute force and pry the small lips between the two?
Second question, since this isn't normal does that indicate there is something wrong within the front differential?
thanks, good way to start my weekend.
