Fuel pressure
justins81213
New member
Cuba,Mo
Have a 2006 Ford ranger sport 3.0 2wd.
Does any one know what the fuel pressure specs are for my truck.I would like to do a girl pressure check but don't know the range it should fall in. I would like both engine running and not running. Thanks!
Rock Auto 5% Discount Code: 173A8B749AB83C Expires: January 1, 2020
Uncle Gump
Well-known member
873
Plano IL
Lead, Follow or get out of my way
A girl pressure check is totally dependent on time of month... and also factoring in would be if you pissed her off prior to pressure testing.
I don't retain the actual numbers in memory for fuel pressure... check the how to tech section they are probably there.
Well-known member
722
55psi is the running pressure, +/- 5psi
Key off pressure should stay above 20psi
