Fuel pressure
justins81213
4
Cuba,Mo
Have a 2006 Ford ranger sport 3.0 2wd.
Does any one know what the fuel pressure specs are for my truck.I would like to do a girl pressure check but don't know the range it should fall in. I would like both engine running and not running. Thanks!
Uncle Gump
Token Old Guy
13,437
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
A girl pressure check is totally dependent on time of month... and also factoring in would be if you pissed her off prior to pressure testing.
I don't retain the actual numbers in memory for fuel pressure... check the how to tech section they are probably there.
8,369
55psi is the running pressure, +/- 5psi
Key off pressure should stay above 20psi
