Fueul pump brands that don't suck!?!?!
BlackBII
Ranger Custom
166
UT
Bosch pump here working great.
I did have an Airtex/Wells pump and it stranded me up in the mountains.
Rock Auto 5% Discount Code: 173A8B749AB83C Expires: January 1, 2020
racsan
Well-known member
280
central ohio
1994 (mostly)
2.3/140-4
built, not bought
I do miss the days of engine mounted mechanical pumps that only cost $30.
(yes, im THAT old)
PetroleumJunkie412
2.9 Mafia
1,917
Pittsburgh, PA
I really need to write a tech article on this one.
Under $40, and allows you delete the frame pump.
ecgreen
Active member
32
Dunbarton NH
Just ordered a bosch, we shall see. I should cut me an access hole...
racsan
Well-known member
280
central ohio
1994 (mostly)
2.3/140-4
built, not bought
that would be hard to do without damaging something. I do pull the bed on a truck when I replace one rather than drop the tank.
1,469
Spectre...thats what I bought last time. Didnt even get 20 miles out of it.
Spectre, the name says all you need to know.
1,469
I have found that the fuel pump in the B2 can be removed without even taking the skid plate out.
Removing the front skid plate bolts lets it hang enough that you can get the tank strap bolts out with a wrench, and that lets the tank hang down enough that the pump can be removed over the axle.
ecgreen
Active member
32
Dunbarton NH
i will absolutely try this
