Gauge cluster
Shitbox
13
Orting, Wa
Bronco 2
Does anyone know any common problems with where the voltage regulator for the gauge cluster gets its power. Tried a different cluster, fuel and temp dont work. Replaced sensor and sending unit . 2.8l 1985 b2
franklin2
1,758
Virginia
Find the temperature sensor on the engine and unplug it. With the key in run, engine off, have someone watch the temp gauge as you take the wire to the sensor and ground it to a good ground on the engine block. The gauge should swing full scale hot or cold. Then take the sensor wire off ground and let it hang in the air. The gauge should swing opposite full scale. If it passes this test, it will verify you do have voltage to the gauge and the gauge and the wiring are good to the sensor.
Shitbox
13
Orting, Wa
Bronco 2
Yeah I already did that test it didnt work , I ended up puting an aftermarket gauge and sensor and will be doing the same for the fuel, I just got tired of trying to figuring out why it didnt have power . This thing sat for 10 years and I'm already about 2k over budget
franklin2
1,758
Virginia
Actually that solution was probably the best. What in the world is "normal" anyway on the gauge? Now you have real numbers.
wildbill23c
577
Southwestern Idaho
215/70-R14
Definitely. Although the gauges seem to work in my 88 Bronco 2 and my 87 Ranger I'd still rather have actual gauges I have a set (voltage, oil pressure, and coolant temp) for my Bronco 2 I haven't yet installed, and I need to do the same with my Ranger I just got too. I don't trust those glorified idiot light gauges LOL.
I had a set of mechanical gauges in my 84 Bronco 2 and found it a very good investment to know exactly what's going on I do need to install a transmission temp gauge in the Bronco 2 as well, just haven't really figured out how to do so properly.
