Going from dual exhaust back to single?
askthemasses
Seattle, WA
On my ranger, the PO put in a dual exhaust and it's rotted to hell and has a bunch of rust hols formed or forming. Looking at replacement exhausts, should I just go back to stock single exit? If so, do I need to do anything else to like the cat or can I just bolt right up? Or should I stick with dual?
Unsure of the pros/cons of either, and whether going from one to another requires any special installation adjustments.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Modern fuel injected vehicles are not "de-tuned" or use anything to restrict power. The factory exhaust was engineered for maximum power and efficiency (and emissions). For the most part changing your exhaust is just to change the sound UNLESS you have from headers to tailpipe and also have the vehicle professionally tuned to make use of any extra gains in flow. That gain would be very limited anyway and is generally a trade off between where your powerband is, and fuel efficiency. So I personally recommend just going back to the full OEM single system. The OEM system is generally designed for meximum midrange power which is what you want on a daily driver anyway. Stock parts are usually much cheaper as well.
You asked about the cat, now do you have a dual exhaust system from the cat back or is it true duel exhaust with a post cat on each side? If its just duel from the cat back you can reuse the cat and just switch the duel back to a single tailpipe and muffler.
askthemasses
Seattle, WA
That's the plan. Just making sure it is really as simple as chucking the old exhaust and bolting the new one up to the cat.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Read the last edited part of my post. Depends how its currently setup. But either way, yes you just need to bolt the oem stuff back on... how the duel is done depends how many parts you will need and if you need new cat(s)
sgtsandman
Aircraft Fuel Tank Diver
12,585
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
As long as it's just from the catalytic, back. Switching back to a single exhaust shouldn't be a problem. Most systems out there are cat back. If they did something to split the exhaust all the way from the front to back, that may be a problem.
