Has anyone dropped a 2019+ Ranger 2.3 engine in a pre-2012 Ranger?
Status
Not open for further replies.
Mike Tonon
Guest
With the performance and fuel economy I’m reading about this new 2.3 and my Ranger being a gas hog 4.0, I’d consider the swap. I don’t absolutely need 6 cylinders. And heck, 2 less cylinders is that much less parts, weight, etc.
Will this engine bolt up to my M5OD-R1HD manual transmission?
Can I make the electronics work in my Ranger, without creating more of a mess than it’s worth?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
No. And also No.
8thTon
--- Banned ---
806
Pennsylvania
Makes sense - buy a brand new truck and rip out the engine to put in an old Ranger. I bet lots of guys have done that swap.
ericbphoto
Overlander in development
16,538
Wellford, SC
6"
Very few people have even installed 2019 Ranger engines into 2019 rangers.
Mike Tonon
Guest
You’re aware you can buy just an engine and not have to buy an entire vehicle, right?
BlackBII
Ranger Custom
Truck of Month
982
UT
The 2019 Ranger uses a turbo charged 2.3 Duratec. The *same engine that's in the Mustang, Focus ST, etc. This engine evolved from the 2.3 in the 2001+ Ranger, which evolved from the Mazda 2.0 mzr, which evolved from the 1.8, and so on.
This is mostly conjecture, but if we go off the incomplete information we have, chances are the block and bell housing bolt patterns are close to the same. So, it would actually be quite simple to install a 2019 2.3 in an older Ranger. You would need motor mounts and a transmission from a 2001+ 2.3 Ranger. You'd need to solve things like fuel lines and an ECU to start with.
However, because this engine technically already exists in a Ranger, I would recommend buying a 2001+ Ranger with a 2.3 already in it, then pull the engine, put in some forged internals, add a turbo and tune it and you'd end up with an equivalent to the 2019 engine.
17,771
SW Iowa
Ranger850
Doesn't get Sarcasm . . .
4,685
Tallahassee Florida
Stock 2"
Stock
no 2.3, but this is as close as it gets. Im hereby applying the term to this swap as a "2.Go":icon_hornsup:
snoranger
Professional money waster
ASE Certified Tech
13,625
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
A 2.3l ecoboost crate motor lists for $6500. The control pack adds another $2k to that.
Most people have a budget when they're building a project. $8k for an engine in a Ranger seems like it eat up the budget pretty quick. It's more common for people to buy a motor from a wrecked truck.... it's just too soon.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Not to mention a new trans.... so there's another few grand.
The original question was
will the trans fit - no
Can it be done wihout being a hassle - no
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
645
Central Indiana
It's pretty likely that the engine shares a bellhousing pattern with the Duratec 2.3 from 01+ (like most 4 cyl Ecoboosts) but that's speculation since it has a brand new 10 spd trans in it's natural home. It will not work with your current 4.0 based trans. It will not work with your current PCM or wiring.
That engine in the 2019 Rangers only comes with a 10spd auto which is enormous and would require lots of tunnel work to get into an older Ranger. That also means that a 2019 Ranger PCM can't be used for the swap because it will be looking for a 10 spd auto, and not a 5 spd manual. No older Ranger PCM will be able to control an ecoboost, even with a tune, because the ecoboost is direct injected, so you're stuck spending big bucks on Ford Racing's control pack + a manual transmission
The only realistic way you're getting an ecoboost into an older Ranger is to use a manual trans from a Duratec truck, NC Miata, or Ecoboost Mustang. Obviously the Ranger trans will be fastest/easiest in a Ranger. If you want 4wd, in theory you should be able to frankenstein the Duratec Ranger trans with the current tailhousing/transfer case in your truck but I've never seen it done. And then you get to startcutting the firewall and ripping out the things that make the truck enjoyable (like heat/AC, power steering, etc) to fit the turbo and high pressure fuel pump into the truck.
fastpakr
2,832
Roanoke, VA
How big -is- the 10R80? I found the weight listed quickly (230lb's) but nothing for other dimensions.
17,771
SW Iowa
Wrecks are out there, just not from a truck. 4cyl Ecoboost swaps have been done (as noted in my previous post)
O No 3.0!
62
Knoxville Tn
Ranger xl 3.0
So nobody has done a 15K engine & trans swap on a $1500 truck? Huh, weird....
Ranger850
4,685
Tallahassee Florida
Stock 2"
Stock
Status
