Headliner, supercab, all day job??
alwaysFlOoReD
5,088
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The seat belt bolts have factory thread locker. They can be a pain. Some heat will help....be careful.
Josh B
1,986
Oklahoma
These are the instructions from the Ford manual for 93-94, it doesn't say much about doors or windows ( or seatbelts ) but I haven't done mine yet either. I looked online a while back and it seemed they are available for a little over 200 dollars
I also watched a utube video of it being done and the guy made it look easy
30347
30348
Elutheros
129
Central Texas
I've done a couple and having the seats out enables getting it out the passenger side. Probably a 4 hour job, but not all day.
Russella1
7
Yellville, AR
Ranger XLT Supe
2.9 L
N/A
N/A
New Old Stock
I have done this before. You have to take the seats out and slide it through the Passenger Door.
Junk Collector
Truck of Month
4,797
Rapid City SD
I did one headliner for a single cab Ranger a while back. It was a very frustrating experience. The fabric was purchased from Joann's like the OP did and a single can of spray glue... that shit is expensive at $20/can. I ran out before I had coated the whole works and used regular spray glue to finish the rest. Then, it pulled apart around the sun visor areas after it dried so I had to cut slots in the backing board and spray glue in there and then weight it down with a grocery bag full of lead shotgun shot that spread out to the shape of the sun visor dimples.
I learned a lot. I hope I never have to do another one. But if I do... weights in certain areas and having enough glue on hand during the process will make it a lot less stressful.
Make sure you note how the fabric folds over the front and back, if it does. I cut it flush at the back and realized after I installed it that it should have been folded over. Looks weird cut flush.
