high idle before and after engine swap
Angie
Active member
28
Vancouver area BC Canada
92 & 83 project
4.0L 302
thanks floored, figured something should have changed. well this is starting to narrow down the problem. sorry for not diving deeper into the IAC way back when you asked about it, just never downed on me that it would be wiring issues, and not the device itself.
makes good sense though considering that same b4 and after the swapped engines.
Rock Auto 5% Discount Code: CFB3B5F7F32B37 Expires: March 30, 2020
Angie
Active member
28
92 & 83 project
4.0L 302
ok, made a jumper from another harness. 3.0 volts running with engine warm. 10.5 ohms, cold and warm picture shows what i jumped. any insight to what is normal? also loosened off the bolts holding this in the intake. pulled the piece up to open it and a large vacuum leak started, kept pulling and the engine wanted to die as too large of area was exposed. also, there is another air item sensor in the intake. un plugged this and still no differences.
Angie
Active member
28
92 & 83 project
4.0L 302
thanks, interesting info. will take a look at the tps during the week upcoming. cheers
