How much oil is too much?!
Mike Tonon
Guest
I had my oil changed and after it was about a quarter inch above the top hole in the dipstick. Is that going to blow gaskets? What does the top hole, mean? Is that the absolute top of the safe range and the top of the hashes/X’s is where it ideally should be? Thanks
Rock Auto 5% Discount Code: 248EE46702D889 Expires: October 1, 2019
Dirtman
Well-known member
EMT / Paramedic
1,026
Over there --->
466.63 teaspoons.
So friggin big!
Give me money.
You are most welcome.
ericbphoto
Old Redneck just wingin' it.
620
Wellford, SC
6"
I’m sure there is some room for error. How much? I don’t know. 1/4” is probably ok. The level on the stick changes when the vehicle is not level and that rarely causes trouble. Of course, it’s not hard to drain some out.
alwaysFlOoReD
Forum Moderator
330
Red Deer, Canada
'91, '94, '80
Ford, GMC
4.0,4.0,350
I have overfilled regularly on an oil leaker I had. I cannot say it did any harm, but who really knows?
Dirtman
Well-known member
EMT / Paramedic
1,026
Over there --->
466.63 teaspoons.
So friggin big!
Give me money.
You spent like 3 months discussing the proper mix of differential and transmission fluids yet took your truck to a jiffy lube for an oil change...
Mike Tonon
Guest
No, dirtbag, I had free oil changes from the dealer, from when I bought the truck there 12 years ago. They use synthetic blend and usually do a good job.
rusty ol ranger
Well-known member
394
Michigan
2.9L
Youre better off being a qt low then a qt over.
That being said the 1/2qt or whatever yours was over shouldnt of hurt nothing.
racsan
Well-known member
188
central ohio
1994 (mostly)
2.3/140-4
built, not bought
I never worry about being “a bit” over. Think of it this way, you check the oil with engine not running. When it is running it’s in circulation and there’s possibly 1/2 qt of oil NOT in the pan because it’s on it’s way to the rocker arms or other places, so it’s doubtful that even at 1/2 a qt over you’d be churning the oil up with the crankshaft counterweights and rod ends. If I have a capacity of 4-1/2 qts, I’m still putting 5 in (like 4.3’s in S-10 blazers) I’ve never had a issue doing that.
ericbphoto
620
Wellford, SC
6"
Seems to me that the guy designing the marks on the dipstick would/should have thought of that.
Well-known member
1,115
Being over won't blow gaskets. It can slow the crank, but on a big engine like that you won't really notice it.
The bigger issue, and this is more of a problem on an automatic trans than an engine, is it can allow fluid cavitation that can effect the pressure in the system.
