I’m Sure the Answer’s “No,” but... Drain Bolt on the Torque Converter?
I just thought about something. Isn’t the trans pan on an A4LD aluminum? Mine looks reeeeealy shiny for steel... :icon_confused:
I dunno, go get a kitchen magnet and try sticking that to it, see if it is ferrous or not.
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
Not aluminum unless after market pan.
rangerenthiusiast
Hudson Valley, NY
Right you guys were. Plopped a magnet against the outside of the pan and she sticks. Further inspection reveals that the PO shot some crappy silver spray paint on it. :icon_rofl:
Thanks, as always.
kimcrwbr1
46
maplevalley WA
2.8l
If there is a drain it would be through the flywheel at least ther is one on my C-3 torque converter. Pull the dust shield for the bell housing and rotate the flywheel there will be a hole betwee two of the torque converter bolts and a plug inside the hole?
