- Aug 6, 2007
- 200
- Age
- 47
- Berrien Springs, MI
- RE Interceptor
- My credo
- If you can't go through it or around it, then go over it.
what kind of transfer case would you have to run if your front axle was offset to the driver side and the rear axle was off set to the pass side?
Ok the desired set up is in black, the optional is that purplish color (was supposed to be red)
Is there a Transfer case that will give me my desired set up? if not, can a fixed yoke and a CV style joint be used for the optional?
