Ignition Switch Wiring
8,369
Does the 2004 ignition switch have slotted holes?
Could be the rod is pulling too far for START and not pushing far enough for ACC
Mike92STX
58
Zion,Illinois
Well I got it working, the problem is I don't know what I did. I was trying to take the keyed ignition out and couldn't locate the button to push in to get it to come out, after a couple of tries I took the housing off the steering column and still couldn't push the button in enough to take the ignition out. I was getting cold so I decided to put it back together and try another time. While I was lining up the covers I noticed that the key looked like it was turned back a little further than it was before so I checked the radio and wipers and they work in acc. ?? The only thing I can think of is the PO had the keyed ignition out and didn't get back in correctly. I just now thought that I should have checked the button to see if it was sticking out further then it was when I was trying to push it. I'm happy because even if stops working again I know where to start.
RonD THANKS AGAIN for you help.
8,369
Good work
Thanks for posting the FIX, hopefully its stays working
Bastogne22
IL
Welcome to TRS :)
Yes, one yellow wire comes from the 50amp fuse(#11) and splits into 4 yellow wires at the ignition switch
Yes, with ignition switched in START position, its sends 12v out to fuse #24 on a red/blue wire
The key cylinder uses a gear and pulls and pushes the Actuator rod inside the steering column to slide the ignition switch into its 4 positions, ACC, OFF, RUN, START
Can you test the ignition switch manually?
You could have a problem with Actuator Rod not moving ignition switch all the way to START position
That same red/blue wire also sends power to fuse #28 which should MUTE the radio for startup
Can you use a momentary push button switch to bypass a broken actuator that won't reach the start position in an Automatic? Something like this?
Amazon.com: DaierTek 2pcs Momentary Horn Push Button Switch 12V Black Metal Waterproof 19mm Round Starter Power Switch for Car RV Truck Boat Marine : Automotive
Yellow wire to one terminal and red/blue wire to the other terminal?
