ignition switch?
lyndo
north carolina
just brought my 85 ranger back to life. It will not run unless I hold the key in the barley start position, not enough to engage the starter but beyond the run position. hart to drive a straight drive with one left hand. When I first got it it would die sometimes, then start right back up and go on. cleaned some grounds and it seemed better. then I found if it did the intermittent knock off , I could touch the key just a bit and it would keep running. then I would flip the key ring over the top of the key holder and lett the other keys hang off the back side. I seem to remember a there were two ignition wires, one for starting and one for run. Your thoughts?
8,369
The key cylinder is not the ignition switch
Ignition switch is on the under side of steering column above brake pedal area
The key cylinder has a gear on the end, and that gear slides a rod, the actuator rod, when you turn the key, that rod runs down to the ignition switch
The Ignition switch is a slide switch, that the rod moves into its 4 positions, ACC, OFF, RUN, START
Could be ignition switch is just worn out, the contacts, I would pull it out and have a look
There should just be the one Yellow wire from engine bay to the ignition switch, it does split at the ignition switch to 2 or 3 attachment points
lyndo
north carolina
update. I went out and messed w/ it and had the thought about the key vs ignition switch. I notice when I put it in run position the emision light and one below it would not stay on. I kept playing with it until the dummy lights stayed on. fired up and stayed running, unless i hit a bump. thanks for your input , I will have a look tomorrow
