interchangable parts list
whocares
1995 Mustang seats are a direct bolt in using your RBV seat tracks...if I knew more about Mustangs I could tell you the other years too, but someone can chime in with it.
twoll86
9
caseyville,il
79-04 mustang seats are a direct swap with rbv tracks
The M5OD bolts into place of the A4LD and FM146 as long as the number of cylinders on the donor and recipient match.
If replacing an FM145 you need to find a drive shaft of appropriate length for your vehicle (4.0 M5OD shaft from a vehicle with same wheelbase) and move the trans cross-member brackets to the rear holes. Shifter plates for the floor board have to be modified slightly or there is a hole in your floor the size of my head (see my album).
1350 to 1354 t-case swap is fairly direct bolt in. You may need the linkage and definitely the front d-shaft from the donor.
twoll86
9
caseyville,il
feellnfroggy
28
Knoxville, TN
twoll86
9
caseyville,il
ive seen a 91 body on a 99 frame with the 99s dash and engine and some other interior parts
Grenth89Ranger
Paradise, Ca
2.3L
I am very interested in parts that will fit my 89 ranger... upon a visual experiance i noticed that the headlights from bronco and some explorers but unaware of the years used,l will fit my 89 ranger....
i am also interested in what type of bucket seats will fit with little to no modification on my 89 ranger im really hating this bench style seat that is falling apart , and would like to place cup holders and possibly some speakers in the center ....
thanks in advance and im hoping this is the right section to place this in .. if not im sorry
twoll86
9
caseyville,il
89-92 ranger 89-90 b2 and 91-94 explorer headlights
as far as seeat b2 ranger and explore seats withranger tracks
Grenth89Ranger
Paradise, Ca
2.3L
thank you so much .. njow when u say ranger tracksdoes this mean you can directly bolt on those tracks or do u need to shim and other modification ... (Really sorry but never really have done much interior work on any vehicle except paint, and clearcoating lol thanks so much btw im glad i have joined this forum :) )
feellnfroggy
28
Knoxville, TN
For what its worht my 93 ext cab took a set of leather power buckets from a 99 expo without modification. Same bolt pattern, I havent wired it up yet though. Ill do a build thread when/if I do.
twoll86
9
caseyville,il
bolt right up and actually ive put f150/bronco buckets in just hade 2 dill the rear holes
Grenth89Ranger
Paradise, Ca
2.3L
sweet .. what year of F- 150 .. i might have access to a free pair of buckets from an f-150 at my grandpas :)
twoll86
9
caseyville,il
it was an early 90s
twoll86
9
caseyville,il
