Jet Size Reccomendations?
1984ranger28
5
Davison, Michigan
2.8l
Hi, a previous owner has removed the smog pump, the EGR, and made a dual exhaust with just cherry bombs. When accelerating, there seems to be no difference between 1/2 throttle and full throttle. So any suggestions for the jet size? Thanks, Lucas.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Is it cable linkage? If so you can get rid of cable stretch by adding a few small zip ties to the cable end. Google cable zip tie mod.
1984ranger28
5
Davison, Michigan
2.8l
Its not that, there is almost no play in the gas pedal.
8thTon
--- Banned ---
806
Pennsylvania
Once the throttle plates are open far enough to flow as much air as the engine is capable of drawing at that rpm, opening them further won't do anything. Depending on what carb you have and what rpm range you are focusing on it might not be a jetting issue.
