Jumpy throttle
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
So on to the next part of my 89 build. When I push the gas pedal, there is a brief hesitation and sometimes its very jumpy when it kicks in. I am thinking: clean the throttle body and maybe the cable is stretched? Any help appreciated (as usual)
8,369
Yes, cleaning is always good
Check throttle spring, and lube throttle cable, take it off at the engine end, lift it up and spray lube down it, then slide it in and out a few times
Also check throttle position sensor(TPS) when its off, ohm meter is best
TPS serves the same purpose as the Accelerator Pump on a Carb, tells computer to squirt in extra gas when you push down on gas pedal to prevent a hesitation like you describe
4.0blue98
I don't feel tardy...
678
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
C'mon Ron, keep it clean. This is a family show. ;)
Sounds like an issue I had with a TPS once though.
8,369
I am a dirty bird, what can I say
