remreid12
- May 19, 2019
- 0
- Fond du Lac, WI
- Ford Ranger FX4
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
So I just bought my first ranger, a 2008 FX4 (4.0 auto supercab 4x4) with 175k miles. It runs well and the frame/body are in great shape for being from the midwest. It has a few things I need to fix, and I was wondering if any of you have gone through some of these repairs and might have some warnings or suggestions. I'm hoping to keep this truck for a while so I'd like to repair everything properly.
-differential leaks from pinion seal and rear cover (cover is quite rusty and needs replacement)
-transmission pan seal leak & shift shaft seal leak
-exhaust leak at manifold outlet flange
-check engine light (P2270) - "Oxygen sensor signal stuck lean bank 1 sensor 2"
-from a quick google search it appears that this could be from that exhaust leak
-front lower control arm bushing warn out on the spindle side
-rear main seal leak
I'm also thinking about trying to undercoat the inside of the fenders, bottom of the doors, rockers, and frame before winter. I'd really hate to see the salt ruin this truck, as it will be my daily driver.
Thanks in advance for any suggestions. I apologize for any apparent ignorance of mine if there are threads about these issues already. I'm still finding my way around the forum.
