Sdude2008
- Sep 11, 2007
- 18
- Farmington CT
- Ford
- Engine Type
- 3.0 V6
- Engine Size
- 3.0 Flex
- 2WD / 4WD
- 4WD
- Tire Size
- 31x10.5x15
1999 3.0 87k. suddenly left turn signals dont work. fuses good, pulled all four corners and swapped bulbs all good, dont have tilt wheel but checked wires to multifunction plugs none loose, removed multi switch and cleaned sprayed down with electronics cleaner no change. flasher flashes right side only and right blinker works. can't afford to throw parts at it. anyone with a similar problem? any ideas? Thanks.
