Low dollar B II project
fix_or_repair_daily
SW PA
Ford,Chevy,Satu
2.3, 5.7, 1.9
Hi, I am starting to collect parts and pieces for my bronco. Here is what I am going for:
Front end: f150 coil spacers, d28 w/open 4.10 (can get for free), Rough Country steering stabilizer and 2" lift RC8000 shocks, urethane axle pivot and radius arm bushings
Rear end:7.5 w/4.10 and Lockright locker, chevy 1500 2" lowering shackles, 2" lift RC8000 shocks, shortened Exploder rear driveshaft
2"or 3" body lift w/ new urethane bushings (mine are trash)
15x8 Cragar soft 8 black wheels and 31" or 32" tires (looking at Trailcutter ATs or RTs on ebay)
Drivetrain: stock 2.9,A4lD (yes I know POS! but works good for now)and man shift t-case also plan on adding a larger trans cooler
I plan on mostly on street use, but want to do some mild playing off road. Also, 99% of the time I drive my vehicles easy so I'm not too afraid of breaking stuff.
I am open to your suggestions and comments.
Thanks, Josh
Evan
5
Stevens Point, WI
4.0 OHV
For a street rig designed for a little offroading now and then, that looks like a good setup.
Don't know if you were already planning to, but get manual locking hubs for the front.
You could try getting an 8.8 from the rear of an Explorer and swapping in a Dana 35 front out of an early 90s Ranger, Bronco II, or Explorer. This would allow you to lock the front axle and move up to 33s or 35s, depending on wheelwell clearance.
derekj
Squamish, BC
Ranger 4wd
Sounds like the exact same road I am going down. I have an A4LD torn apart on my bench right now with all the parts sitting next to it for a rebuild. Should get it back together next week after the holidays. Then i have a 2.9 in the shed waiting for a rebuild and will put them in together. My lockrite should be in the mail soon as well. I did a coil spacer up front and an add-a-leaf in the back. When winter is over I will add a 2" body lift so i can fit my 31's on. Can't wait to get it out and do some wheeling. Good luck with your build!
Derek
squig9
Josh, I have the following new in box; Performance Accessories 3" Body Lift for '89-90 BII #70003, James Duff Polyurethane Body Mounts #6394, Frt & Rear sway bar bushings #6336 & #6323, Spring eye bushings #6382. If interested KEN kcwils@frontiernet.net
bullitt
Prophetstown,IL
2.9
Sounds kinda like mine...or at least what i started out to do. I bought my bII for 300$ and the front Superlift 4inch lift for 200$. Good start right?....Well once i started i adapted this "if im gonna do it, do it right the first time".....about 3k later, lol. But i'm happy with it. I bought a 91 Ranger off my buddy, reg. cab with a 4.0 and 8.8 rear end, which is what i swapped into my BII with a Ford Racing Trac Lok diff. It's 28 spline, but it's still beafier than the 7.5, and you dont have to mess around with re positioning the spring perches and stuff. I opted out that way cause i was trying to get it done in a certain amount of time, if i would have took my time i'da thought more, and spent less. My a4ld shifts pretty good, i'd rather have a manual, but what can you do. It had manual t-case and lockout's, so that was a plus. Good luck with your build.
