Manual Shift BW1350 Linkage
ford4wd08
Active member
87
Alcoa, TN
2.8 V6
Hi all,
I need help finding the correct part name for the round white bushing the manual shift transfer case linkage has in it.
I broke mine while I was taking the auto trans out. I'll try to snap a pic of it tonight.
I can't seem to find one anywhere on line.
The shifting linkage has like a "U" that fits in between this bushing.
Rock Auto 5% Discount Code: CFB3B5F7F32B37 Expires: March 30, 2020
fastpakr
Forum Moderator
333
Roanoke, VA
You aren't talking about something like this, are you?
30537
snoranger
This page left blank intentionally
ASE Certified Tech
1,501
Jackson, NJ
'79,'94,'02,'17
All Fords
3L5Z-7335-AA
It's not exactly the same, it's for a newer Ranger but it should work.
ford4wd08
Active member
87
Alcoa, TN
2.8 V6
3L5Z-7335-AA
Yes, that looks very similar! The one I have is a full circle.
I was going to make something, or try to repair mine if I couldn't find one!
snoranger
ASE Certified Tech
1,501
Jackson, NJ
'79,'94,'02,'17
All Fords
The original full circle one was discontinued years ago. This one is used on newer Rangers, but it will work fine in place of the older one.
ford4wd08
Active member
87
Alcoa, TN
2.8 V6
Awesome, thank you for the information.
snoranger
ASE Certified Tech
1,501
Jackson, NJ
'79,'94,'02,'17
All Fords
I snapped a pic of mine tonight.
It is actually not bad. I might just glue some washers to the side of it and reuse it.
That's fine... put it back in and use it like that.
