More Dana 35 bullsh*t
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Looks like a cast aluminum bronze to me. Not fun to weld. Need ER-AlCu a1 rod, AC frequency with heavy cleaning, and a good pre and post heat. Brazing will just crack off by the time it cools.
kunar
131
Toledo, Ohio
5.8l
Wire wheel the pumpkin where the beam and pinch bolt touch it. Put it back together and forget about it. Seriously, i've run one like this many years and many miles, no worries. The pinch bolt still does its job.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Cleaned it up. Nice big pinhole right in the bottom. it was still holding fluid, though.
alwaysFlOoReD
5,080
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Drill and tap the pin hole for a pipe plug?
sgtsandman
Aircraft Fuel Tank Diver
12,533
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Looks like you bought yourself a nice, big old paper weight...
EDIT: The tapping for a drain plug isn't a bad idea. Make lemon Aid out of lemons.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
At this point, I'm hoping someone counterattacks my trebuchet barrages with D35 housings. This is some serious bullsh*t.
Paid $150 for a frame section and engine. So far, the only good part is the new clutch that was on the 4.0
alwaysFlOoReD
5,080
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I believe the pin hole is on top.
When I took a pre-app diesel mech course, one of the ways to repair a cracked block was to drill and tap for pipe plugs. Each succeeding plug cut into the one beside it locking it in place. I don't remember what was done to lock the last one in place.
sgtsandman
12,533
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Damn it! I was hoping that was the bottom. Thanks for the explanation though. That makes sense.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Yeah... wait... I thought that was the bottom as well...
FlOoReD, did you get into my stash or something??
alwaysFlOoReD
5,080
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Hmm, I have been feeling a little woozy. Maybe the pain pills are finally kicking in.... I was positive I read in your post that the pin hole was on top, but I just checked and nope, you said bottom. Oh well, let me crawl back into bed and I'll shut my pie hole....
sgtsandman
12,533
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
It goes into the bolt hole for the diff cover. I call no joy. Unless you really shorten the bolt to allow the plug to fit.
alwaysFlOoReD
5,080
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Use a brass plug then. Carefully dremel the part sticking into the bolt hole and then tap it. Maybe at the same time elongate the bolt hole so it can be used as a drain?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Grind that thing into powder and turn it into thermite.
17,753
SW Iowa
I can only counter attack with D28 chunks...
I guess I would try to find a way to stabilize the oxidation, goober a little JB weld in the hole so it doesn't collect stuff and continue doing its thing and go. It might have been a casting defect from day 1, it seems like an odd way for something to rot out. Do run a pinch bolt though, there have been reports of people running without them and cracking axle beams. I don't see one missing flange for the pinch bolt being a big deal.
