Most reliable Ranger configuration?
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
615
Central Indiana
3.0's last forever but you'll be lucky to get more than 20mpg long term. I think my vote goes to the 01+Duratec/5spd combo. They should be pretty bulletproof and will get about 30mpg on the hwy. They'll also be some of the newest trucks, so you're less likely to have age related issues with things like vacuum lines, brake lines, etc. The newest 3rd gen Ranger on the road is now 22 years old, and that's a long time for things to break down/corrode/ turn brittle/get hacked by previous owners, etc.
No matter what year, or configuration you end up with, definitely hold out for a manual transmission. They're generally more fun, get better fuel economy, and have far better long term reliability.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,380
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I would agree with the Lima family of engines on a non 4X4 Ranger. Tough call on a 4X4 model. They each has their weak points. Maybe the most reliable engine would be a toss up between the 3.0 and the 2010-2011 4.0. The catch with the 4.0 is that if the time chains eat it, you will need to pull the engine and special tooling.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I would have put the dtech at the top of my list if not for the same reasons as the 4.0 sohc. Pain in the ass maintenance. With the 4.0 its timing chains, the dtech it's the egr valve and coolant lines that both require pulling the transmission for service. You could pretty much rebuild a entire 2.3 lima, 3.0, and 4.0 ohv without even taking it out of the truck. Ease of maintenance = reliability.
Josh B
1,957
Oklahoma
How are you going to rebuild a 4.0 ohv without pulling the engine?
The book says pull the engine just to do a timing chain
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
OHV only has one timing chain on the front and is a simple job, it's just a pushrod motor. The SOHC has twin timing chains with one on the rear that cant be removed without pulling the engine.
Josh B
1,957
Oklahoma
You don't have to pull the motor on a 93 4.0ohv?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
The timing chain is on the front, one short simple chain. What would be the necessity of pulling the engine for that?
85_Ranger4x4
17,488
SW Iowa
Everything has to come out for a rebuild.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Why? Not questioning you. Never rebuilt a 4.0ohv. But it's a simple pushrod engine? I'm not talking about machining work. But timing chain, cam, heads, valvetrain, pretty much everything but the crank should be able to come out with the block in the truck? What makes it necessary to pull the engine?
85_Ranger4x4
17,488
SW Iowa
Overhaul is just doing the top end like you describe. Underhaul is just doing rod/main bearings and looking for obvious damage on the crank. Rebuild is everything.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Ok I mis-spoke. My point was the 4.0ohv can be fully serviced or maintained, pick your wording lol, without pulling the engine. Aka chain, cam, heads etc. Where the 4.0ohc and 2.3 duratec both have required basic maintenance items that require pulling the motor or trans. Aka timing chain, egr valve, and coolant hoses.
So there's nothing SHORT of a full rebuild that would require pulling a 2.3 lima, 3.0, or 4.0ohv.
snoranger
Professional money waster
ASE Certified Tech
13,522
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
You don't even have to pull the water pump to do the timing chain on a 4.0 OHV. You can leave it bolted to the timing cover and pull it as a whole assembly.
rusty ol ranger
Im a Jeep guy now.
7,267
Michigan
177 CID
If you keep it cool and dont mind noisy lifters.....i still say the 2.9 is the most reliable.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
How long did it take you to get yours running even close to normal? A year? Yea... super reliable. :icon_rofl:
Be honest, does it even run now without a cel? And I mean without you pulling the bulb out.
Kirby N.
March Truck of The Month
