MtnMotoADV's '88 XLT 4x4
mtnmotoadv
Bitterroot Valley, MT
1993
Merry Christmas!!!
Got my Rigid pods installed.
Sweet-85'
Hastings, MN
Ford Bronco II
2.8 V6
2.8L 171CID
If it ain't broke, fix it 'till it is!
mtnmotoadv
1993
Thanks 85.
Bedsides were more difficult to cut.
Turned out okay.
And i was able to cut out most the rust in the front and back.
Wishing I would have gone with 33”s...
Now I just need to decide what to do with the front suspension.
With the rear GM 64” leafs and flipped long shackle, there’s not much lift at all, right?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
the frame is like a slinky so stock rear articulation on an extended cab has never been an issue for me untill the chassis is tied up with a cage or something......even then its pretty good.
but for max traction and ability...the chevy 63 swap has merit for sure.
the key to the front is
tooooooo soft to safely drive on the road coils, tamed to road-ability with airbags. very cheap path for optimum tun-ability
long arms
super duty aftermarket detachable sway bars
"k link" style steering setup.
unless you can afford coilovers.. even then you get max slow speed travel out of soft coils.
mtnmotoadv
1993
Painted the hood and roof black.
No more rust! I don’t think it looks too bad.
Lighting makes it look uneven.
USCGC130
106
sacramento
5.5"
Love the build man , everything looks very well done. I plan to do my spare the same way, just offset to the passenger side, do you have any advice?
