My 1996 Ford Ranger 4x4 (TRS-2) Re-Build
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,539
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Yes, I will definitely be bringing it to Texas once I get it finished.
deathbypsi
06/2012 STOTM Winner
MTOTM Winner
79
Mich
2.3turbo
I would do 35s for sure to gain as much ground clearance as possible under the frame since its a longer wheelbase truck.
Another option that would be perfect for that wheelbase is run a doubler. I just seen on one of my Ranger FB groups someone is making the shaft and plate to build a 1350 doubler again ,just like I have in my Truggy.
Jim Oaks
Administrator
Supporting Vendor
8,539
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
I'm going to use this as more of an adventure rig. I hate to lose the climbing ability it has now, but not quite sure I would get a lot of use out of the doubler.
Playing around with a new paint scheme idea. My paint scheme has always been a play on the Ford Rough Riders paint scheme.
This time instead of all the stars, I'm thinking just one big star on each side, and making the red stripe curve, instead of coming to a point. But unlike how the Rough Riders pattern goes across the hood, I'll continue the blue with the red stripe all the way out to the headlight like the original TRS-2 paint job. :icon_idea:
Jim Oaks
Administrator
Supporting Vendor
8,539
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
I need a tailgate that's in good shape to fit my 1996 Ranger. I also need the bolts and latches that attach to the bed that the tailgate latches on to. Mine are gone. I want the tailgate so I can use it as a bench/counter/table when I'm camping. I also want to remove the spare tire from my cage, so I can put a 12-volt fridge in between the cage and have access to it. It would be great if I could put it on a slider, so I can pull it out to get in to it.
This means I need to relocate the spare tire either back under the bed, or on a new rear bumper with a swing out tire carrier. Honestly with the time crunch for the anniversary, and the other things I need to get done, the only way I could probably do a new bumper and tire carrier is if I found someone that could help out and build it for me.
I'd still like to see if there would be people interested in coming over on a weekend this spring to help do some work. The Ranger is in Dennison, Ohio 44621.
Bird76Mojo
1,264
IL
That gen of tailgate is abundant on Ebay and Craigslist.
GB :)
BlackBII
Ranger Custom
Truck of Month
982
UT
I would absolutely come help if I was closer. All I can do from here is offer encouragement. You got this! If you put the work in, you'll get the results. :icon_thumby:
Sent from my Pixel 3 using Tapatalk
Ranger850
Doesn't get Sarcasm . . .
4,664
Tallahassee Florida
Stock 2"
Stock
SAME:icon_thumby:
17,528
SW Iowa
Same, wish it was closer. :sad:
Mightyfordranger
156
Ohio
2.9
3in
Clean your room before you criticise the world.
I'm only an hour from there just outside of Akron. Ill see what I can do to help Jim!! I think I have a clean 98 green tail gate that may still be in decent shape. Also I do have a 200 amp tig and a arc machine as well. I'm trying to find a decent smaller mig here soon. I do have a whole 98 single cab to rob parts from. (Its wrecked though in the front).
Post up a date when you'll be coming up and I'll do what I can to be there.
Jim Oaks
Administrator
Supporting Vendor
8,539
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Sounds awesome, thanks!!
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,667
woodhaven mi
FORD mostly
BIGGER
sawzall?
about 1.5 miles from 250 on north on 151. my truck is in the yard so you cant miss it....same one i was in last time i met you..
plan for this week is to put front axle parts/lockouts in and hot test/ load test the power-train before tearing into it. i was wanting to build a little work bench and stuff before tearing into it...garage is plain jane so any tools are welcome.
Jim Oaks
Administrator
Supporting Vendor
8,539
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Really starting to wish I hadn't sold my chop saw and tubing bender. I need to build a new rear bumper, and reposition the spare tire.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,667
woodhaven mi
FORD mostly
BIGGER
sawzall?
theres a welder and chop saw and pipe bender here. its pipe though. so sch 40 hrew ect are materials needed...
tubing bender not too far away though. pretty sure pottsy still has one too.
mighty ford.....i work nights....12-15 hrs depending how far away and 7 days. not sure if you have my number. i am on a few phones since i last talked to a..same number though.
Mightyfordranger
156
Ohio
2.9
3in
I work 2nd shift currently 6 days a week. I just bought a 02 ext cab to build. Its not legal yet. But I'm working on all that. I think I need to toss a clutch in it. But once its good enough to make the trip down. I can load up some welders. I'll see what I can do about bringing some DOM with as well.
One question though...will we have heat??
Also Jim check your PM box sent ya one.
Oh and I maybe able to bring some kind of a work bench as well. I'll have to score a trailer from my brother.
Jim Oaks
Administrator
Supporting Vendor
8,539
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
The more I think about the truck, the more I start losing sleep trying to come up with a plan. One of the things weighing on my mind is the engine. I replaced the original motor back in 2014 with one from a 1996 Ford Explorer. I have no idea how many miles are on the engine, but I know Bobby said it has a leak at the cylinder head. I haven't been reunited with it it. I plan to go out and tear in to it this spring.
Other than being stock, the motor has a Jet Performance Module and Borla exhaust.
I'm throwing around some engine ideas, and I know there are expenses that aren't listed, but I'm trying to get some idea of options and cost.:
Rebuild / Overhaul Option #1:
Engine Gasket Kit: Sealed Power Engine Kit Gasket Set 2601699 - $114
Rocker Arms: Melling Rocker Arms MR-927 - $99.00 ($8.25 each)
Timing Set: Sealed Power KT4028S timing set - $67.00
Stock Replacement Pushrods: Sealed Power RP3332 - $57.00 ($4.75 each) (5.48")
Oil pump: Melling: M128 Oil Pump $70.00
Oil Pump Pickup Tube: Melling 345S Oil Pump Pickup Tube $46.00
Total = $453.00 (assuming all of the rocker arms are replaced)
Rebuild / Overhaul Option #2:
Replacement Cylinder Heads - $500-$600 (pair)
Total = $854.00 (Replacement heads)
Rebuild Upgrade #1:
Comp Cams 49-410-8 camshaft - $295.00
Smith Bros NH54A-DD 5.550" Pushrods - $144.00 ($11.95 each)
Total = $835.00 (Rebuilt factory heads & camshaft upgrade)
Rebuild Upgrade #2:
Comp Cams 49-422-8 (or 410) camshaft - $295.00
Comp Cams 988-12 Dual Valve Spring - $67.00 (set of 12)
Comp Cams CCA-775-16 Spring Retainers - $55.00 (set)
Engine Gasket Kit: Sealed Power Engine Kit Gasket Set 2601699 - $114.00
Total = $1,357 - $1,457 (Replacement heads with upgraded camshaft)
Explorer 5.0L Swap:
Engine & Trans - $500-$600
BW4406 Transfer Case - $200
Cylinder Head Gasket Kit - $60.00
Oil Pump - $31.00
Timing Chain Set - $35.00
Timing Cover Gasket Set - $14.00
Crank Seals - $14.00
Oil Pan Gasket - $16.00
Total = $870-$970
Here's a really good deal on an engine donor:
https://tuscarawas.craigslist.org/cto/d/new-philadelphia-ford-explorer-awd-675/6803625136.html
This assumes that the engine is in good mechanical condition and just needs freshened up with gaskets, seals, oil pump, and timing set. This doesn't include motor mounts and all the other things that might be needed?
Will also need some driveshaft mods.
I know some of you may think you should just replace everything with a V8. I've been very please with the performance of the 4.0L. I've had a 302 Ranger 4x4, and they're great for throwing mud, so I know the benefits of a V8. I want a reliable truck that I can travel all across the country in.
Anyone have any advise as to why I shouldn't just overhaul the 4.0L in it now??
Kirby N.
March Truck of The Month
