Mystery Black Box
6herald6
What is the little black box that the ant. output cable enters before it exits with the coax cable to the ant.? Also, this box has another cable coming out of it and into a stereo plug?
Thank you,
Fred
Pics?
Sounds like a satellite converter box.
6herald6
Pics?
Thank you,
Fred
Tnx. for the quick reply. Tried to upload a pic but it said file too big.
Open it in paint and resize to 900x1200 pixles. Should help.
ericbphoto
Overlander in development
16,530
Wellford, SC
3.0L
6"
I agree with adsm08. It sounds like a box used by auxiliary items like a satellite radio receiver. It allows the auxiliary item to inject an fm signal directly into the antenna cable. So to listen to the satellite radio, you set your tuner to the frequency that that box is injecting.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Like I told the last guy. C4 is extremely difficult to detonate. Heak we use to burn it to heat up MREs. If you pull out the blasting caps you'll be perfectly safe.
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
Secret government tracking module. Lets them know where you've been, route you took. Also lets them know what type of music you listen too so they can figure if your
brain has been effected by "subversive music rot".
If you disconnect it, your Ranger will self destruct.
Grumpaw
6herald6
Grumpaw
A "bug", eh. I was afraid of that! :rolleyes:
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Bomb jokes aside. Looks to me like an FM transmitter to use an aux Jack or bluetooth on a radio that doesn't have those features. I have one in my truck. Looks pretty similar.
If it is that, it simply hijacks the radio antenna to transmit to an output for your phone or whatever. There would be either a 3.5mm Jack somewhere. Or when you get in the truck a random bluetooth signal.
6herald6
Ok, that certainly explains it. Thanks!
6herald6
I'm thinking this box's function is receive mode. I don't think the car ant. is used for transmitting.
Fred
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
No no how these things work is let the antenna in like normal to let it out to the radio... yay listen to FM 96.5, then separate the antenna into a signal to a separate device that typically wouldn't use radio frequency satellite, xm, I phone, whatever so it can play over the radios speakers.
It just hijacks the FM signal to play other stuff on a crappy radio.
6herald6
Fred
the small gauge cable with the 1/8" plug goes into the sig. input of the devices you just mentioned?
ericbphoto
16,530
Wellford, SC
3.0L
6"
No. It's an fm output from the device. It is injected into the antenna wire going to the vehicle's regular stereo system. You tune the radio to that frequency and hear the output from the auxiliary device through your regular stereo.
