Need help on 98 ford ranger airbag system
Austinsned
New member
Alabama
Ford ranger
Hey everyone im new here and need help. I recently bought a project 98 ford ranger and i have found out someone put more work into hiding stuff then fixing it. Truck was in a front end collision and they rigged up headlights and they also told me it needed a fuel pump. I replaced the fuel sending unit and that wasnt it and it wasnt the kill switch so i did more research and found that the ecu was bad. I put a new ecu from the dealer in and it runs great now. I went to honk the horn messing around and heard a crack and found that the airbag want in there and i realized they glued it shut very nicely where you couldnt tell at all. What all do i need to replace? It dont have pretensioners but ik ill need atleast the wheel air bag and the left crash sensor. Is there a module i have to replace? Should i go ahead and do both airbags and sensors? Can i use junkyard parts? Any advice helps.
Rock Auto 5% Discount Code: 57CD9601BD5AB4 Expires: July 1, 2019
97RangerXLT
Forum Moderator
130
Fishers, IN
2"
31"
go drop a burning bag of dog crap on the previous owners porch.
I believe that the 98 has the old style air bags athat blow full force when they are triggered... so hopefully the guy that hid all of this got his nose broken in the accident. you will need all of what you mentioned, and you will probably need a scanner that will allow you to reset the airbag codes and turn off the light. make sure that the lights on the dash are operative, including the one below the ashtray that indicates teh passenger bag is off.
I would go a head and get the entire components for the system from a junkyard (one vehicle if possible), and you may need the VIN of the donor truck as well, not sure of that tho, to add them to your truck.
Not airbag related, but if the truck was in an accident that blew both airbags (or even one) and the PO was a big enough scumbag to hide it from you, there is likely some other hidden damage besides the lights and what not. you might double check the frame and make sure everything is properly aligned...
AJ
Austinsned
New member
Alabama
Ford ranger
AJ
Thank you! And yes once i found that today i started looking for more hidden damages. As of rn i have not found anything else but there is not telling. Luckily i just have a love for this truck and plan on rebuilding it. And yes i wish i remembered how to get to his house cause he is sorry. He better be lucky i didnt have a wreck or something cause that would be a hell of a lawsuit.
