New member from pa
SGE
8
Pennsylvania
Hello all I’ve owned 2 rangers in the past but I’m looking at a 2001 with a 3.0 and 5 speed. It has 195,000 miles and it’s a 2wd. The owner wants $1000. Haven’t looked at it yet but it looks good in the pictures.
Should I be concerned about anything in particular?
Josh B
1,960
Oklahoma
Hey SGE, welcome to TRS. I have no Idea your experience with anything, but my first few steps are fairly straightforward and simple.
I don't want anyone "showing" me a vehicle, I prefer they pretty much stand back and allow me to look at it, and do not want it to be warmed up or cranked before I do.
On the first basic walk around simply look at the body for damage, fenders, doors etc out of alignment and such, but that's a simple cover-up of sorts, because during the walk-around reach down and wipe your finger around in the tailpipe(that in itself might tell you all you want to know)
If it passes that test go underneath, look for loose hanging wires, busted shocks, rusted frames, transmission or other parts with wrecking yard chalk on them, lots of oil leaks, etc.
Then under the hood and basically do the same, considerable wiring harness "alterations" can be a bad sign. Look at the oil dipstick for rust or signs of water in the oil(if the oil has just been changed is not always a sign of "proper maintenance")
Then get in, (hood still up) looking for all the above, considerable alterations etc, dashboard out of alignment.
Set the parking brake and start it up and let it idle, get out and walk around it slowly, listening closely to the engine and looking for rough idling etc. At the tail pipe smell the fumes for excess fuel etc. listen to the motor carefully a bit. Reach over the the throttle cable if it's visible and slowly increase the rpm.
Then take it for a drive checking first for brakes, then for proper shifting through the gears(whether auto or manual) and listen to driveline components, wheel bearings, steering etc
That's a simple list, and could be greatly expanded depending on experience
SGE
8
Pennsylvania
Thank you! I appreciate the advice
pjtoledo
2,914
Toledo Ohio
Fords
3.0 2.3
you're in the rust belt, take a small hammer and tap the frame looking for soft spots and holes.
pay particular attention to the rear, and where the front & back halves are spliced together.
also the bottom of the radiator support where it attaches to the frame.
  • Like
Reactions: SGE
SGE
8
Pennsylvania
Ok I’ll do that thanks.
Bgunner
1,039
Western Mass.
Ford/Ranger XLT
225/70/R15
As for frame issues be sure to look well also at the frame mounts for the cabs, these have a tendency to rot. in front of and behind both front and rear spring hangers as these are common spots for rot also. Just add these to the list of mentioned items to look at since these are common issues with frames in these years.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Hello fellow Pennsylvanian.
There is only one way to test drive a potentially new to you Ranger:
Doughnuts.
SGE
8
Pennsylvania
Appreciate the advise. I’m also looking at a 97 and possibly a 94 today. I’ll keep all of this in mind
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
So. How were the Doughnuts?!
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Damn good deal.
Pics!!!!!
SGE
8
Pennsylvania
4.0blue98
I don't feel tardy...
672
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
Looks good!
Kirby N.
March Truck of The Month
