- Jan 2, 2009
- 0
- New Jersey
- Ford
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
Just installed a re-manufactured rack and pinion from auto zone along with new power steering lines. After bleeding the system and refilling with mercon 5 trans fluid & taking for a test ride power steering has gone away after 3 turns. Steering turns freely when jacked up in the air but once put down on the ground it is very tight and hard to steer. Is it possible that the pump has now gone bad? When you look in the power steering reservoir you see very little fluid circulation.
99 Ford Ranger 4x4 xlt 3.0 v-thaks in advance for help & suggestions
Also I have the pressure line in the bottom rack port and the shorter line to the cooler in the top port.
