new source for manual shifter?? F150!
pjtoledo
2,956
Toledo Ohio
Fords
3.0 2.3
adapting F150 shifter to Ranger
this tranny is from the 3.0 '99 rollover I stripped last summer. the BW 1350 is from a yard up near Bobby's area. I only bought the 1350 for it's shifting internals.
shifter is from a 2000 F150 4.2 auto with BW4406 manual.
currently it's only attached by 1 bolt, I'll need to move the other hole and finesse the location to fit the Rangers floor. maybe bend the handle a bit too.
still in the preliminary stages, need to do some thinkin & scratchin. :icon_confused:
the transfer case is in 2Hi, 4lo would have the arm level.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
or just make one.
17,768
SW Iowa
You need the most common lever:
A4LD shifter (on a C5 which obviously isn't fitting)
The two different style levers for the 1350, A4LD on the right:
Ford made at least two levers for the t-case too, looks like you have the longer one which is what you need.
More 1350 shifter fun here:
https://therangerstation.com/forums/showthread.php?t=103015&highlight=request
Also the detents are not really strong in the t-case, not sure how well they will stay in gear (or how well you can find a gear) without the gate like the stock shifter.
