veefer800canuck
- Sep 7, 2007
- 7
- Alberta
- Ranger FX4
- Engine Size
- 4.0
Picking up my new-to-me 2011 Ranger FX4 this week. Grey, 5 speed
I've been looking for wheel/tire combos, and trying to see what will fit, with mild mods.
So far, I've discovered the 2008+ trucks are lowered from the factory.
OK, dial in the torsion bars and fit the Belltech 6400 shackles.
So that's about 2" right there for next to nothing. Easy.
Planning on running 285/70-17 tires with 17x8 wheels.
I think I will also need a 3" body lift, found the PA lift, no problem.
What I can't tell right now is: Wheel offset.
Most 17x8 wheels I am looking at come with a 10mm offset.
The ones I want to get (and are affordable) are the Ion Alloy type 179
http://www.wheelsforless.com/IO179-7865B
According to Ford, the stock ranger 16" wheels have a 12mm offset.
https://www.fleet.ford.com/TRUCKBBAS/topics/2011/2011_Ranger.pdf
Running the two wheel specs gives me the following info:
So 11mm less clearance on the inside with the wheels seems like it might be a Very Bad Thing (tm)
Add to that the fact that the tires will be 1.2 inches wider, so an extra 0.6" on the inside.
So tires and wheel combined make for 1.03 inches LESS clearance on the inside.
What I need to know is, will this work, or do I need some zero offset wheels for sure???
Anyone????
Anyone????
