No A.C. after pressure washing engine
Tonytitan
New member
Nashville TN
I took a pressure washer to my engine compartment to knock some of the grime out. Looks like I knocked out my AC in the cabin also. It doesn't appear to be a problem with cooling; the tubes carrying refrigerant are cool and wet with condensation. I think it's a vacuum/door control issue. I have no vacuum at the heater control valve regardless of setting. I get hot air out of all outlets all the time. At interstate speeds hot air blows thru the heater outlets even with the control switch set to off. When I leave the interstate it stops blowing. I clamped off the coolant to the heater core but the best I get is ambient, uncool air. Every vacuum line I can find is in place and secure. I'm so confused!
The truck is a 1998 Ranger 2.5l 5-speed.
Rock Auto 5% Discount Code: CFB3B5F7F32B37 Expires: March 30, 2020
Blu Bug
New member
Having same problem. No one answered you so, I guess no one would answer me either.
Dirtman
Well-known member
EMT / Paramedic
3,068
Over there --->
466.63 teaspoons.
So friggin big!
Give me money.
Don't power wash your engine.
Denisefwd93
Well-known member
56
South East PA
I don't know about the 98 but earlier rangers use a cable for the bypass door. The newer ones use a electric mechanism also on the heater compartment in the dash, but you probably have airbags that will compound your issue
IIBRONCOS
AZ
2.9
Now you know just one of the reasons you shouldn't power wash an engine in a vehicle. Ask me how I know... It is tempting though and looks so good when you're done.
RangerRock
Madera, Pa
I sugesst going through the vacuum lines one by one. Have an 03 Focus, was having issues with my EGR causing it to fail inpection. Afyer replacing and testing individual components and $200 later found a small pin hole in a vacuum line. Dont take much of a hole to stop vacuum actuators from working.
You may have washed some crud off your vacuum lines and have a small vacuum leak or got water in a check valve and its stuck not allowing vacuum to the hvac controls.
Though i believe the blend door in the 98 and newer are electric actuators.
Dirtman
Well-known member
EMT / Paramedic
3,068
Over there --->
466.63 teaspoons.
So friggin big!
Give me money.
The blend door is electric but the vent actuators are still vacuum. Simple way to test for vacuum leaks on the hvac system, let the truck sit for 10-15 minutes then pull the line off the resevior. If it hisses the hvac system is holding vacuum...
