O/D off light
Jack99
Moody
Ford Ranger xlt
Jack99
Hello everyone, I need some help. I have a 99 ford ranger xlt 2wd, 4.0 v6 mfi ohv
With 5R55e transmission was rebuilt October last year. My o/d off light blinks on/off driving 40 to 45 mph with air conditioning on, come to stop sign then start slow speed get almost to 40 mph take my foot off gas. Then apply gas to higher speed od off start blinking.
To give a history it has new fuel pump, plugs, plug wires, icv, maf, trottle body, engine run smooth and great. Need help on code p0735.
Appreciate any help!
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
The od light has codes like the check engine light. Scan it.... get the codes
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Sorry p0735 is bad gear ratio in fifth. Give details on what your rebuild was.
Jack99
Moody
Ford Ranger xlt
Trans was pulled for reverse at transmission shop, fixed reverse. All foward gears worked ok. If i drive it without ac (load ) trams has not had any codes
The p0735 is 5th gear ratio code pops up when ac is on. The transmission shop went back in and recheck trans again replaced inside wiring harness, speed sensor. It has a speed sensor on rear differential. That jas not been replaced.
Dors this info help
Ed
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
Check front band adjustment to be correct.
Jack99
Moody
Ford Ranger xlt
Thanks, I'am fixing to replace speed sensor on rear differential with motorcraft dy 1123. Any more ideas is appreciated.
Jack99
Moody
Ford Ranger xlt
Would ac being on or not have anything to do the 5tg gear ratio code?
PeterPuck
Calgary
Jack99
Hey Jack, I'm having the same issues. What was your solution?
