oil filter housing?????????
upriverjoe
:hi:88,Bll,2.9, i have continually had problems with my oil filter housing (the part top of the filter that bolts to the block)becoming loose and wobbly and leaking oil. i can't get one through the dealer, so i've replaced mine twice with ones from the wrecking yard but the same problem occurs. any suggestions would be highly appreciated.
thanks
holyford86
Some guy with a problem
610
Plattsburgh, NY
many
33x12.50R15
I had the same problem with my 86, I used an oil filter housing off of a '98 4.0 that I had laying around and it stopped all leaks. They work better because they don't use a copper washer, its all "o" rings. Just make sure that you get all new "o" rings if you go that route.
