oil preference/recommendation
Zapper
Yes i can afford this without "daddies money"
45
Buhl,ID
1986ish
ford ranger
2.294e+6 cubic millimeters
shot bushings?
235/75/r15
To send it or not to send it, that is the question.
I hate oil discussions but I will simply state this. I send samples to Blackstone and ran Mobil 1 5w20 for the first 6 or so years. Tests showed slightly higher than average copper and iron wear. I then switched to pennzoil ultra platinum 5w20 (super cheap on amazon) and subsequent tests showed iron and copper wear dropped below average. So now I buy pennzoil ultra for everything. 5 quart jug on amazon is 19.99 when on sale.
I need to do the Blackstone labs thing the next time i change my oil, i still have my old oil from when i last changed it but that is a weird concoction of atf, coolant, gear oil, 5w-30, and gasoline, so it wouldn't be worth it to send them that
snoranger
Professional money waster
ASE Certified Tech
13,625
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
That would be normal for a 2.9L
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Josh B
1,986
Oklahoma
Catch an oil sample as soon as you pull the plug, easy to do with a pit. Never tried it on the ground, might need to change your angle of attack to find a good position from which to get both hands up there, pull the plug with one and grab the first oil that comes out with the other
Josh B
1,986
Oklahoma
After reading the replies on this thread, tho maybe not all, I'm wondering what's happened to the Motorcraft?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
The blackstone instructions say NOT to do this. Take the sample halfway through the draining process. If you do it as soon as you open the plug you can get sediment/sludge in the sample which will ruin the test.
Josh B
1,986
Oklahoma
In my experience you cannot get it there fast enough for that, the plug must be moved out of the way before putting the sample container in its' path, allowing any sediments disturbed/released by removing the plug to be already gone.
It' may be a good idea to wipe away any excessive accumulation before even starting, with a shop rag or air hose
Actually the ones I did it on were mostly International semi tractor diesel engines that held about 5 gallons, and we pulled a sample every 15,000 mile oil change(about every 3 weeks in a truck's life) and sent it in for analysis.
Their reasoning was more tuned to the principle that the heavier particles they were looking for would be mostly metallic, settle more rapidly to the bottom(even on a warm engine), and be mostly gone any later in the draining process ;)
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
How dang big is your bung hole that you cant get a sample container under there quick enough...
:icon_rofl:
Their instructions not mine.
Josh B
1,986
Oklahoma
Unscrew bolt, move bolt, put sample container there, at least the first half pint or so has already gone flying by, taking any loose dirt with it. If they found any dirt/sand in there it wouldn't alarm them much, we didn't use that often in our engines :D
I was standing up straight in a 3 foot wide pit, had plenty of room in there ;)
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Lucky ****
I work on gravel, and I believe each stone was personally sharpened by satan himself.
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
Fumoto valve.
snoranger
ASE Certified Tech
13,625
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
The best thing to do is pull the drain plug while the engine is still running and mixing the oil. :cool:
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Fumoto valve.
These things always made me nervous, not that I've ever heard anyone complain about them but something about just having a lever to drain the oil makes me uneasy.. I like the femco ones that have a cap, and then you screw on the hose to make the oil start draining. Still no tools required but a little more "secure".
Josh B
1,986
Oklahoma
Dammm! I never thought of that! :D
Everlearn
104
Louisville KY
Ford Ranger 4x4
If your short term memory is as bad as mine is, you’d end up with a seized motor............?
