Oil Pressure Switch.
gungfudan
19
Mississippi
Mazda
N/A
N/A
I am doing to oil pressure gauge fix and would like to know where is the oil pressure switch located?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Right side of the engine block towards the rear below the head. Only thing threaded into the block there with a one wire connection.
8,370
Yes, behind the passenger side head on the block next to the bell housing
Not sure the PS60 sender will fit in there, may need to add an extension
ericbphoto
Overlander in development
16,592
Wellford, SC
6"
It's tight back there. I removed the original switch and replaced it with an elbow fitting and braided steel hose to remote mounted pressure sensor. About the only way I could touch the original location was from below the truck.
Royal PITA
RangerVet
34
Kingman, AZ
FordRanger Edge
From here on down it's uphill all the way!
I am mounting an oil pressure gauge under my '05's dash as the truck did not come with one. I purchased a spacer from Amazon that mounts in between the oil filter and the block. There are 4 ports on the spacer or pillow to tap into. I am mounting an oil pressure sender onto one of the ports so it sends information by a wire to the electronic gauge. There is plenty of room in the engine bay to do this. I purchased the parts at NAPA and used a VDO gauge.
gungfudan
19
Mississippi
Mazda
N/A
N/A
Royal PITA
Where did you find the elbow and SS braided line?
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
It'll fit. Get a hammer.
ericbphoto
16,592
Wellford, SC
6"
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I bought a Glowshift oil filter sandwich adaptor from amazon. The quality of the piece was top notch... been on my truck since Aug of 18. Zero issues this far.
I like it... it leaves the factory switch/warning light system untouched. On a 4.0L it left lots of room for a gauge sender and/or mechanical connection.
gungfudan
19
Mississippi
Mazda
N/A
N/A
What thread size did you purchase?
Never mind I figured it out. It is 3/4"-16 Thread.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You've seen the light... these are pretty slick and zero headaches.
