Pinion angle and driveshaft u joint angles?
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
Its time to build a driveshaft for my Ranger. I'm using a full width 8.8 out of a 92-96 F-150. I've chosen to use an Explorer driveshaft and have it shortened. I was talking to the driveshaft guy and he said that the pinion angle and output flange have to be within 4 degrees of each other. I have a 7 degree difference.
My pinion is pointing straight at the back of the tcase. I for some reason thought that was the way to build it when I built it. I researched some and basically what I've found for a perfect street vehicle (Except mines a lifted truck) that the pinion angle needs to be in line with the output of the tcase.
If I lower pinion down to the same angle as the drivetrain the u joint would have a bad angle on it. If I lower the drivetrain to match the pinion it would be hanging down so low. I don't understand how any of this is possible and how a lifted truck could maintain these specific guidelines.
Does anyone have any clue on what to do? I'm so lost...
Ford78
December 2012 OTOTM
Iowa
351w
If the angle's are bad you will want a cv style drive shaft. With a cv driveshaft u will need the rear pinion pointed at the transfercase. With just regular u joints you need the pinion at the same degree as the transfercase yoke/flange.
Hagan
11
Salem, OR
2.3
Thank you Ford78!
I guess I will need a cv style driveshaft. Is it possible to attach a cv directly to a yoke (ujoint to yoke)? I know my 92 Brono has a cv at the tcase but it's a flange. So maybe I'll pull just the cv at a junk yard.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
I'm not a guru and haven't researched this for a long time. The b-2's used a double carden joint...it's two u-joints beside each other. Perhaps something similar could be built for you. And here is a link to a pdf from ford;
http://www.therangerstation.com/forums/attachment.php?attachmentid=12939&d=1389987591
thats what 78 meant by a cv joint.
i would run the single single first with the pinion about 1-1.5 degrees lower then the t case so its perfect under cruise conditions. just put heavy tack welds on the perches....if its good....weld the perches up. if you dont like it re-configure with the cv style to work with your setup....they can be whatever you need.....flange-strap-bolt....pick your ideal.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I've always thought a "cv" joint was the one with the balls and sockets.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
it is.
but the double carden joint is also mis-nomered as a cv joint as well...well sort of.. it is a type of cv joint, but not as true as the ball style.
Ford78
December 2012 OTOTM
Iowa
351w
That's what I meant, I could not think of the real name for it, cv was just popping in my head.
Hagan
11
Salem, OR
2.3
I should run a single ujoint on each end first? Then if it doesn't work switch to a double cardan?
Thanks!
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
thats what i would do.
simpler and cost effective.
just put the pinion down a degree or so so it rolls up good under load.
.5-1.5 degrees usually works great for me. depends on how soft the springs are and how often you load it up heavy etc.
don4331
1,342
Calgary, AB
5.3
Hagan:
Not sure a couple of your questions were addressed:
Jim did a really good article in '08: http://www.therangerstation.com/Magazine/summer2008/ujoints.shtml
So, if you don't have too crazy of gears, reasonably large tires and don't drive too fast, you should be fine. My Ranger at 100 km/h, (31x10.5R15/4.10s) has drive shaft rpm of ~2,700, so 7° would be slightly excessive (won't last rated life/there will be vibration).
There are yoke double cardans - if you have Jeep transfer case, there is hope, otherwise odds get real slim. See Tom Wood's, http://www.4xshaft.com/ Double Cardan conversion for examples.
Don
  • ryan
    Forum Administrator
