Please post your axle photos..........
BLOODBANE
19
Canon City, CO
FORDFORD
347, 4.oh
HP D44 out of a '79, F/S Bronco(pulled by Warrlord/Thumper113)
and the 9" to match (same vehicle)
These will go into my Ranger( as soon as I'm convinced the 347 it right and I get off my lazy rear-end)
JohnnyU
"Outlaw"
8
Chillicothe, Illinois
Chevrolet
Ls2
HP Dana 60 from 1979 F250 SnowFighter:
Installed in 1991 Chevy:
GM 14FF SRW:
1badexplorer
Firefighter
4
Sutersville Pa
3.0, 501, 7.3psd, 351c, 351w
Does anyone still want dana 60 pics?
Is there anyone that still wants pics of a dana 60 in a truck? I got a 78/79 style in one truck that I can post pics of and a 84-up kingpin style in another truck that I can post pics of. Just let me know and I can get some pics if you want.
1badexplorer
Firefighter
4
Sutersville Pa
dana 60 pics
Oh i also got the one swapped under my exploder that has been swapped to 78/79 ford radius arms and coils. with hydro steer
powerwagon
2.3
hey CheapThrillB2 wut kind of coils did you use on that ranger? im debating a d44/83/4 swap on mine and just wanted to know wut kind of coils to get if i did not use leafs?
powerwagon
2.3
id post my axel pics but all my danas are dodge pasenger side
ziptie
Houghton, Mi.
1977 Early Bronco D44 (Disk Brakes)
Stripped for custom brackets
stroked88ranger
Colorado
4.0L V-6 245 CID
Just waiting to come back from iraq so i can prep my truck to put these bad boys in...
Iron Ranger
Run lil' ricer RUN!!
MTOTM Winner
22
Minnesota
0.040 punched 302
Ford 9"
shortened a total of 9"(4 1/2" each side), from a 1978 F-150, swapped the 2.75 gears for 3.89. New end flanges are from Quick Performance Racing. Ford Racing 11" drums(still get to keep the 5x4.5 wheel pattern). Drain hole was added as was the new shock mounts.
This was actually one of the easier setups that my brother and I tackled. As long as your math is right, everything should come out nicely.
No more weakness, no more c-clips or rear diff covers.:yahoo: Perfect!!!!:icon_thumby:
Toreadorranger
5
Sal
Currie HD 9" housing built to Early Bronco width.
1badexplorer
Firefighter
4
Sutersville Pa
Here are some pics of 79 ford dana 60 fronts.
pics of the axle installed.
I also have a 79 d60 in my 74 bronco.
pic of stock factory 79 front hub
pics of aftermarket hubs for D60
CheapThrillB2
May 2010 OTOTM
8
Western Michigan
1975-1995 Ford
FORD
soon 5.8L
1995 D60
1. Its a ball joint 60
2. Its has calipers/Knuckles specific to 94+ D60's. The Knuckles are different then the earlier ball joint 60's
These calipers are about impossible to grind to clear 15" rims with any more then 2.5" back spacing. I had to run a reverse mount rim with 2" Back spacing and still had to grind calipers to clear.
I had to remove 1.5" off the drivers side housing to gain clearance on the tube for the wedges. The 80's+ Ford 60's have a much smaller Left side shaft which makes for less room on that side of the tube.
the reverse mount rims, I welded a set of D44 wedges I removed from a 77 f150 housing and grinded them to fit the 60 tubes.
Here is a SRW 14 bolt (prior to 1988) that has been shaved 1.75"s ( the housing is upside down in the pic)
And bolted under with a modified Ruff Stuff diff cover
NMB2
July 2010 OTOTM Winner
22
Cody, WY
5.0 V8
97 F350 PSD Dana60:
Home made hi-steer arms on the balljoint knuckles:
35spline pr0n:
Ballistic Covers:
Complete (minus front through bolt on hi-steer arms to lo steer arms):
Rear Semi-Float Dana60 from 84 F250. 35spline shafts:
Edit: I also run 15" rims, Grinding was easy w/ 2.5" BS rims.
Josh40601
MTOTM Winner
12
San Diego
Full width 9" on a DD :D
Full width D44 High Pinion
Kirby N.
March Truck of The Month
